IP56 ISOLATOR
IP56 ISOLATOR
IP56 ISOLATOR
We have an inverter panel that will use the schneider VCCF1 as an isolator, the problem is that the panel is to be rated IP56 and this isolator is rated IP65 does anyone know of a similar product that is IP56 or a way to make the VCCF1 ip56.
Thanks very much
Liam
RE: IP56 ISOLATOR
What part of the world are you in?
RE: IP56 ISOLATOR
I'm in the uk
RE: IP56 ISOLATOR
Kraus & Naimer have plenty which achieve IP66/67 in their catalogue. Generally a decent brand too.
RE: IP56 ISOLATOR
Thanks very much
RE: IP56 ISOLATOR
No problem. Buy me a pint if you're ever up in the north-east. wink
