Overlapping solids and sections
Not sure if there's an easy workarround for this...
I'm currently trying to use Solidedge for some sort of factory foundations layouts, in order to get a parametric 3D model of all the elements involved.
Due to the nature of the work, I have a lot of 3D overlapping in the final assembly (for example between beams and their surrounding concreting), with only one problem: whenever you get a section for two or more overlapping solids, their filling in the draft gets also overlapped. It's not a big deal, but it makes drafts not so easily readable. You can see an example here:
You can't get what I show in the bottom section unless you really remove the sphere from the cube in the 3D model, which is not an option for my complex model.
Is there a way to configure what should Solid Edge do when there's a 3D overlap within sections? For example, having some parts with higher priority than others in order to show their filling in those cases? I would love to avoid having to do "manual" stuff within the drafts, since they are quite complex.
Any ideas?
Much thanks in advance!
Any ideas?
RE: Overlapping solids and sections
In the Display tab under Section uncheck "Show fill style" and select OK.
In the Draft under the Sketching tab select the Fill command.
Manually fill both regions.
http://about.me/davidmerritt
The draft is quite complex, and having to do manual stuff will be a big drawback for my purpose, specially because it will be getting a high number of updates.
Thanks in any case
