Non-Stop Solution Calculation - RISA is in a non-stop cyclical loop of solving my model? What's up?
RISA 3D is performing a Solution of my model. the dialog box says, "Solution of Combination 1 in Progress...
Calculate P-Delta Shears..." RISA is "stuck" in this solution loop and will not stop. What is the problem here? What is the fix? Thanks!
RE: Non-Stop Solution Calculation - RISA is in a non-stop cyclical loop of solving my model? What's up?
I looked at the deflected shape and sure enough I've got a Node taking off into the ground. It's a node at the end of a monorail beam. this rail extends about 6 feet outside the building, I've got 2 horizontal braces supporting it and a third member attached to the top of it, kinda like a strut, or knee brace at the top. there's 7.5 kips at the end of the monorail (test load) and it's flying off the paper. I could put a small spring there because I know in real life it will hold up but it's not in the model.
Any suggestions about putting a Spring at that Node/Joint?
Btw, my boss wants all models solved using P-Delta so I've got to find a way to get it to Solve using P-Delta.
Thanks.
I'd check your boudary conditions for accuracy (member fixity/releases for example), or maybe your beam simply is not stiff enough. A spring may be an option if you can define or at least bound the spring stiffness you have.
I also tried changing member sizes but it didn't work. This is like a Cantilever condition with 2 horizontal and one vertical brace attached to the free end.
Like UcfSE mentioned, make sure your beam is turned the strong way. Could be something that simple.
Lunch Time!
If you fix the ends of the two vertical members you'll see that it will solve all load cases. Basically it is a bad arrangement. You probably shouldn't tie the knee brace back into the middle of the beam either, in my opinion.
Sometimes you can get an instability error when you have too many releases at a particular joint. In that case, pick one member end to be fixed. If all the other members connecting at that joint are free, the joint will still be hinged.
Again, thank you all for your input. The model is solving now. I may add a couple more members if I have the space. I agree, it looks very "funky".
Peace!
