Subroutine need fixing
I have a user subroutine which I found freely available online and I am trying to create a .for (FORTRAN file) out of it and use it with my models, I tried fixing it by removing the errors and warnings but I still get some , I have no experience with programming languages but I really need the code in order to run my models , any help in fixing the syntax errors or problems inside it is highly appreciated
I have attached the subroutine in a file for your review, thanks a lot
Kind Regards
RE: Subroutine need fixing
Could you post the file again but post the original: not a version that has been copied into word and has had all the spacing rearranged. If you are using .for, columns
  • 1-5 are for numeric labels
  • 6 for continuation
  • 7..72 for the code.
  • ! anywhere is a comment
  • a non numeric character in column 1 indicates a comment. C is a hangover from Fortran 66 but still widely used.
If you mess with the spacing, nobody will be able to build your program. Could you also post the errors you are getting and which compiler/OS you are using.
Hi xwb ,
thank you for the comments you mentioned
the file was posted initially in one of the forums online and I took it from there ,I tried to fix it by myself but I couldn't , I have already put it inside a Microsoft visual studio 2008 file and I will post it here tomorrow morning.
Thank you again for your comments and hope to hear again from you
