2-speed gearboxes where a stationary caliper brakes/releases an external disc of a planetary system?
Where an external fixed (non rotating) disc brake caliper brakes or releases a (rotating) disc to shift gear?
As to be easily serviceable by just replacing the worn caliper pads.
In most planetary transmissions I know of, brakes are applied but both parts keep rotating together and are not kept stationary.
Likely it will require 2 linked planetary sets just for two speeds.
Are there any such transmissions?
RE: 2-speed gearboxes where a stationary caliper brakes/releases an external disc of a planetary system?
http://www.modeltcentral.com/transmission_animatio...
