Design of shallow circular foundation
Can anyone point me to a good reference for the design of shallow circular (cylindrical) foundations? This is pretty much like a Sonotube-type foundation. This would be a new foundation where a hole is drilled into an existing grade slab (4 inch thick), the earth is dug out up to 4 feet below grade, the reinforcement is installed, and then the concrete is poured in the hole. The foundation would also have to take moment. Thanks in advance.
RE: Design of shallow circular foundation
Four feet below grade? How do you expect to develop any moment with that? What magnitude of load and moment do you expect to achieve with this construction? Do you have frost in your area? Are you prepared to accept frost heave?
I don't know of any good reference for that type of foundation. I doubt that there is one. Why are you doing this? Is the existing slab moving and in need of additional support?
BA
You aren't going to get a lot of strength out of four feet, but the IBC has provisions for determining the lateral resistance of post foundations.
I don't have a current copy with me, but in the 2000 version it was "1805.7 Designs employing lateral bearing"
Brian:
Thanks a million, very interesting std.
