Hidden Solidworks Commands - Open to Public
SBaugh (Mechanical)
A few years ago I created a Hidden Solidworks Commands document and listed it as shared with anyone with the link. I have since updated that link to public. It needs some updating, but please be gentle with it and make sure the command is truly hidden.
For example: If you hold the Tab key down in an assembly and drag your mouse over the components the components Auto Hide and Shift+Tab does the opposite. I never knew that and many of my colleages did not either.
https://docs.google.com/document/d/1YcvxIsCL4swPkw...
Best Regards,
Best Regards,
Scott Baugh, CSWP
Berry Plastics
Cad Admin\Design Engineer
GEASWUG Greater Evansville Area SWUG Leader
www.scottjbaugh.com
FAQ731-376: Eng-Tips.com Forum PoliciesQuote:
"If it's not broke, Don't fix it!"
RE: Hidden Solidworks Commands - Open to Public
Chris
SolidWorks 11
ctopher's home
SolidWorks Legion
One editing note - the "Shift+C" to collapse tree command is listed twice.
The file was created about 2010 or 2011, I think. THe file can now be changed by yourself. If you want to include stuff for just 2012, then add a Title or something that defines the next release.
MartinShane,
I only see one "Shift+C" etc... in the document... where do you see a 2nd one? The one I see is just above
Scott Baugh, CSWP
FAQ731-376: Eng-Tips.com Forum PoliciesBerry Plastics
www.scottjbaugh.com
"To Collapse the tree you do not need to select the "File name" in the very top of the tree. Just select "Shift+C" to collapse everything in the tree."
Scott Baugh, CSWP
www.scottjbaugh.com
