Extrude Operation in NX8.5
Dear All,
When I try to change the end limit of the extrude (double click the feature) from 10mm (Picture Scale1) to 15mm I get the result shown in Picture Scale2.
Does it happen only to me?
Thanx.
Thanx.
RE: Extrude Operation in NX8.5
www.nxjournaling.com
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
It works with the way you mention only if I deselect and re-select the sketch.
Dear John, I cannot open your video file, if you could please attach it again.
Thank you both for your replies.
If you still can't play it, try this link:
Extrude Issue video.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I can see that you have toggled the "Edit with Rollback" option instead of the "Edit Parameters" option. I use the "Edit Parameters" option cause is faster to load the feature.
When I change to that option I have the desired result but not if I have "Edit Parameters" option on (attached video).
Dear cowski,
I did it again, but it doesn't work for me. NX8.5.2.3 (attached video)
Is this happening to me only?
Thank you again.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I did change the curve rule and distance value separately. My method did require a deselect/reselect. When I perform the edit exactly as you describe, I get the same result.
My apologies.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
