How do you open a previous saved version using Teamcenter 8
An assembly has become corrupted & I can no longer open it in NX7.5
Can someone show me how to open up a previous version using Teamcenter?
I've tried searching through the forums but couldnt find what I need.
Thanks.
Thanks.
RE: How do you open a previous saved version using Teamcenter 8
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Win 7 64 bit (Intel(R) Xeon(R) CPU X5650 @2.67GHz)
24.0 GB
NVIDIA Quadro 4000 + NVIDIA Tesla C2050
Try open the assembly Structure Only, and then from the assembly navigator open the components.
If that crashes, close everything, repeat but now open the "lower half" of the components. If this works, the problem is somewhere in the "upper half", try open the next 1/4 of the non-open components etc to find the problematic component.
Open all components fully, then run Part cleanup. Save
Do you synchronize Assembly Arrangements between NX and TC ?
Try turn off this and then try open the assembly.
Tomas
