Watercad modeling
Watercad modeling
I'm using watercad standalone4.5 I've one 500m3 and another 800m3 reservoirs close to each other. What i want is the water from the 800m3 reservoir to enter in to the 500m3 reservoir, to connect the outlet of the 800m3 to the 500m3, and the water delivered to the distribution line by a single pipe, instead of two parallel pipes, from the 500m3. My question is how can I model this in watercad? Should I add their volumes and use as a single reservoir?
The reservoirs are not constructed this is analysis.
