recommended speeds for hydrocarbons
Good Day,
I want to design a pipe for diesel but I need the recommended speed for that.
I hope you help me. Thanks
RE: recommended speeds for hydrocarbons
Your post is too vague to even let contributors properly assist you.
Recommend you read the faq of this forum first.
Want to know the do's and don'ts of Eng-Tips? Read FAQ731-376: Eng-Tips.com Forum Policies.
English not your native language? Looking for some help in getting your question across to others or understanding their answers? Go to forum1529: Translation Assistance for Engineers.
“The beautiful thing about learning is that no one can take it away from you.”
---B.B. King
http://waterhammer.hopout.com.au/
This then needs to be checked with a pressure drop calculation to determine how much pressure you need and how much power. Higher velocity means a smaller pipe, but higher power needed. Use the guide numbers above to get you a rough size and then look at options for at least one pipe size up and down from there. You may find a big difference in power requirements.
Remember pipelines are designed, not chosen by data like this and there are many many other things to consider.
Good luck.
