Item missing from BOM. Labeled as negative quantity
I have an assembly that only has one configuration and about 30 items. Every time I generate a BOM, it leaves out one item. If I then add a balloon that calls out its Part Number, its given part number is "*". If I change the property to Item quantity, it shows "-1". The item is not a part of a subassy and does not have other configurations. I've refreshed, rebooted, restarted and nothing changes. Any ideas?
RE: Item missing from BOM. Labeled as negative quantity
