Carbide Braze Failure Due to Poor Machining of the Steel Holder
I rarely see braze failure for this cause. It is even more rare to see something this extreme.
Link
Link
Thomas J. Walz
Carbide Processors, Inc.
www.carbideprocessors.com
Good engineering starts with a Grainger Catalog.
RE: Carbide Braze Failure Due to Poor Machining of the Steel Holder
Mike Halloran
Pembroke Pines, FL, USA
Thank you for the comment.
sincerely,
Tom Walz
Thomas J. Walz
The tool marks could also be due to poor cutting tool selection and too fast a feed speed or too slow a spindle speed in the milling process. All in all, it’s a really poor machining job. You can not have the carbide tool piece rocking on a high spot on the steel holder piece, as the one picture shows. It must be reasonably well and continuously bedded on the holding steel. Otherwise the brazing should flow to fill minor variations in the surface of a good machining job.
