loads on each rollers
Hi everyone.
I have 9 rollers in semi circle arrangement, receiving 3 tons of total loads.
I want to get the load of the center roller, anybody points me out where can I get this information? or how.
Thank you so much.
cgelang
Thank you so much.
cgelang
RE: loads on each rollers
NX 7.5.5.4 with Teamcenter 8 on win7 64
Intel Xeon @3.2GHz
8GB RAM
Nvidia Quadro 2000
Maximum: 3 tons
Generally somewhere in between.
then sum(cos(theta)^2)*P0 = applied, where theta is the angle (to the vertical) of the roller loads, and P0 is the load in the roller on the CL (the one you're interested in).
another assumption is that the roller loads are equal ... sum(cos(theta))*P0 = applied
Quando Omni Flunkus Moritati
I don't think that's reasonable at all.
Perhaps if all of the rollers are perfectly aligned with each other.
Perhaps if each of the roller supports deflects identically.
Perhaps if the "pallet" (if there even is one) is perfectly flat and very stiff.
alignment and stiffness variations ... sure that an assumption. similar rollers ... i think it's reasonable to assume that the rollers are essentially the same.
My picture looks like this:
Mike
http://www.maintenanceworld.com/Articles/timken/ca...
Thanks MintJulep, the arrangement of the rollers is like what Tmoose has attached.
@rb1957-I agree with your assumptions, but i modify a little to be more close. I just assume that the force by the vertical vector component on 8 rollers(4 @ left & @right) are the same.(though its not, but fair assumption)
Thus load at center roller = 3tons - sum of 8vertical forces on rollers.
Thanks.
cgelang
If your rollers have an arrangement of constraints similar to a cylindrical roller bearing then you can find an analytical approach in any rolling element bearing text. The actual load distribution at the rollers can be greatly affected by the stiffness of the components, dimensional accuracy of the components, and any installed preload or clearance in the assembly.
Hope that helps.
Terry
if you mean you want a symmeric loading (a reasonable assumption) then my post gave two options for that. note my 2nd loading assumed each roller carried the same load, but as a vector, normal to the contact cylinder; so only the vertical component is effective in reacting the applied load.
btw, Tmoose's link wouldn't open for me.
