Blocked sewage pumps - what do you call this in your area?
Hi All,
We are a company from the UK and we sell a device that stops sewage pumps getting blocked up with rags. This is a very common problem and we call this "ragging". How do you refer to this process please?
RE: Blocked sewage pumps - what do you call this in your area?
plugged up???
muffin monster
It probably would be referred to as "clogging". One can buy a "non-clog" pump, a grinder pump, chopper pump, or a screw pump.
http://www.chopperpumps.com/prod_triton.html
Thanks - Clogging is a good word! Found loads of associated jargon as well. We are trying to do some keyword research for our deragger. Maybe should have called it a 'declogger' smile
For ragging - how about "Stuffed-up", this describes the problem as well as the result.
