Frame Deflection
Frame Deflection
Frame Deflection
Can someone help me check a solution?
I have got a frame 10 ft high and 10 ft long. I have a UDL on one side @ 400 lb/ft. Icol = 200 in^4, same for Ibeam. One side is pinned, other side a roller.
I calculated a deflection of 0.2 inches?? Does this sound correct using a standard drift equation.
Also If I place a UDL on the beam of 400 lb/ft how will this affect the deflection?
I am grateful if some of the experts in structural online can help.
How would the deflection change if both ends were fixed? What equation can I use?
NOTE: I am looking for a simplified solution and set of equations I might use.
Thank you for helping me with the above problem.
RE: Frame Deflection
Using method of virtual work I got a deflection of 0.45 in. I would suggest using this method, as you're not going to find accurate equations for the various conditions you want.
Sorry, my frame had two pins.......my mistake.....
What do you get with two pins?, and two fixed ends? (as an independent check)
I'm using a formula developed by Rudolf Budeski - Modern Engineering Interchange.
Would you know how to incorporate loads on the Beam into the drift.
Thank you.
With two pins I get 0.174 in and with two fixed ends 0.03 in.
Thank you.
So it appears the simplified equation is OK.
Can you , or anyone else suggest how to incorporate a UDL on the beam into the deflection.
Thx again
A UDL on the beam would result in a P-delta effect. To incorporate this you can iterate by hand by multiplying the initial deflection by the total gravity load, resulting in a moment. Solve for a new defelection and keep iterating until convergance. Or you can use the amplification factor in the code for P-delta.
Thx
I don't have a copy of the code here with me.
Can you illustrate the calculation using an amplification factor. Assume 400 lbs/ft and one point load at center = 2 kips (as an example).
Can you show this with the deflection with 2 pins?
Thank you so much.
From the Canadian code (I think AISC has an identical provision):
U2 = 1/(1 - (Cf*delta)/(Vf*h))
For your case:
U2 = 1/(1 - (6kip*0.174in)/(4kip*5ft)) = 1.004
Multiply deflection by U2 to get deflection accounting for P-delta
Is this for some kind of school design project?
Thx
Your help was much appreciated.
Any other comments from other would be most welcome as well.
Thx again.
JAE,
I think so...but I'm just bored at work.
Hi JAE
No this is not a school project.
JAE,
I'm at work too.....
Can you add anything further to the discussion? Greatly appreciated.
Thx
