Siemens NX8.5 - own machine from library shows planars and sketches
Hi!
I created my own milling machine and put it in the library. So far everything works fine, but i have a problem with the display of the machine.
In contrast to the assembly in modelling module, which shows no sketches and planars (i did hide the features in the part navigator), all sketches and planars are shown when importing the machine from the library. I couldnt find the difference to the pre-installed machines, which have also all sketches hidden in the part navigator in their modelling modules, but with them, no sketches show on import from the library.
For now, I can still hide the sketches in the manufacturing, but for the later use, there shouldnt be any sketches displayed on import from the libray.
I guess I just missed one checkbox somewhere... but I am clueless so far how (or where) to solve this problem
(nx8.5.0.23, win7/x64/sp1)
thanks!
regards, somiro
thanks!
regards, somiro
RE: Siemens NX8.5 - own machine from library shows planars and sketches
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
(if i understood correctly, the reference set defines how much info is loaded when the assembly is opened, and with 'model' its just the solid?)
And after that You can delete sketches and other unnecessary data. I think it is better then changing reference sets..
kukelyk
If I notice problems, I know where to get better performance, thanks
And to answer SomiRo's parenthetical question, YES, Reference Sets allows you to decide exactly what objects are to be included with a Component when it's added to an Assembly. The default behavior is for the 'Model' Reference Set to contain only the body which represents the actual piece part making up the detailed part file.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
In my experience, the OOTB default is set to "Sheets and Solids", which will grab every sheet and solid body in the part file and add it to the Model reference set. This can be changed (to "solids priority" or "no automation") in the customer defaults: Assemblies -> Site Standards -> Reference Sets.
www.nxjournaling.com
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
