Connecting a 1200x300 Tee to the DN 1200 existing Steel Pipeline
What is the acceptable mtd to connect a DN 1200x300 size tee to an existing DN 1200 Mild steel water transmission pipeline.
Is it possible to weld the new tee to the existing pipeline?.
RE: Connecting a 1200x300 Tee to the DN 1200 existing Steel Pipeline
Do you ready need a 1200*300 tee? Can a welded on branch do the job?
If must have a full tee then cutting the line is required. But a line this size can spring open (or closed) when it is cut and it takes a huge force to pull the line back into place, not to mention the hazard when cutting the line.
We often have to had tees to large lines. We weld a strucute or beam either side of the cut. Weld in the tee then remove the beam
Kevin
