Mass Moment of Inertia on Quintplex Frac Pumps
Does anybody know how to calculate mass moment of inertia on a Quintuplex frac pump?
RE: Mass Moment of Inertia on Quintplex Frac Pumps
Is MoI for hydraulic analysis?
Independent events are seldomly independent.
No it is not, Consider this frac pump is similar to a engine. crank rotates and the piston /connecting rod has a linear motion.
Calculating mass moment of inertia. Summation of all individual component mass x r^2. r is distance from component's individual cg to the CG of the object. You must first find the Center of Gravity of the entire object.
https://en.wikipedia.org/wiki/Moment_of_inertia
