What is lower transformation temperature for 410 stainless steel?
CCT, TTT diagrams would also be helpful.
"If you don't have time to do the job right the first time, when are you going to find time to repair it?"
RE: What is lower transformation temperature for 410 stainless steel?
You need to know the exact chemistry, they make 410 with a very wide range of C, and the HT response can be very different.
Plymouth Tube
~675°C for Ac1 is buried in the text. Seems about right. Thanks muchly.
