Electic Motors for a tool barrow
Hi Guys,
Not sure if this is in the right place but here goes, I am trying to motorized my tool barrow as I am getting tired of dragging it up and down the factory and I wondering if anyone can give me any advice on the type of motor I could use (type? brand? where is comes from? anything really would help and I am willing to dismantle something else to get the motor out).
I don't need a great deal of speed but its going 2 be moving quite a weight, also I was going to power it using a car battery or 2 (again only ideas). The barrow stands 8inchs off the ground so anything smaller than around 6inch tall would be best as I want to mount it under the barrow, directly behind the front wheels.
Thanks for all the help,
RE: Electic Motors for a tool barrow
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
http://www.thetoysavenue.com/gallery/razor-e100-el...
you can get these things used on craigslist for about $20/ea including the controller if you look around a bit. I actually have two of these motors w/controllers in my hobby bin at the moment (was originally going to make a high speed "power wheels" for my older kid - a few years back)
350w Unite Brushed Motor for Electric Bike or Scooter
Model MY016
Voltage 36 Volts DC
Output: 350W
Rated Current 12.8 Amps
Rated Speed 2750 RPM
What do people think? is it to much for what I want? also I have been looking around for batteries and I've found a lot of 36v ones but they only pull 2.5aH and considering the rating for this motor is 12.8 I am assuming they won't do at all, can anyone give me any advice on the sort of battery I would need or should I reconsider the motor completely and look for say a 12v with a higher aH but I feel that without a high amount of gear-age (and I don't really have enough space under the barrow to put it) a 12v won't really work,
thanks for all the help again,
http://www.parkit360.ca/
http://www.haulzall.com/Power-garden-cart-electric...
Mike Halloran
Pembroke Pines, FL, USA
http://www.diyelectriccar.com/forums/
http://www.evsource.com
http://www.evalbum.com
http://kellycontroller.com/
STF
http://www.helitowcart.com/towcarts/light
STF
