VFD for fan speed control
We have a purge fan for a gas/gas heater.The current method to control the flow is to use an inlet box vane control. The client has proposed using a VFD instead. Would this mean that we no longer need the Inlet box vane and hence no actuator to operate it?
RE: VFD for fan speed control
If you need to shut the duct close when fan is off, you will still need the vane.
Gunnar Englund
www.gke.org
"Will work for (the memory of) salami"
Keith Cress
You need to RTFM - it's all there!
Gunnar Englund
www.gke.org
Bill
"Why not the best?"
Jimmy Carter
(My kids tried that one on me...)
