Cross-section forces
I want to take uot from Abaqus cross-section forces (only moment and normal which should be a sum of each nodes in this section) from shell element. I made a free body cut where I indicated elements above and under this cross section (only one row above and under of this elements not every element of this part) and I pointed each nodes on this cross section and as a results I get much lower result (the result is about 10^6 times lower) than I calculate by myself. What should I do to take out cross section forces, what is wrong...?
Greetings
Greetings
RE: Cross-section forces
