ASME B16.5 pressure ratings << ASME 8
I was doing some work today which involved assessing several piping runs to see if a 150 class line was good for 300 class pressures so I could produce an in service justification.
When a standard B16.5 #150 flange is assessed using the criteria in ASME 8, depending on bolt force e.g. 50% yield L7, it can be shown to seal to a considerably higher pressure than indicated in B16.5 (at same temp). Just wondered what the reasons are for this and what the background to the B16.5 code is?
Kind Regards
Nick
Kind Regards
Nick
RE: ASME B16.5 pressure ratings << ASME 8
