Creating Points
Creating Points
Creating Points
could somebody please tell me how I could create points at the intersection of a datum plane and a curve??
RE: Creating Points
Insert - Datum/Point - Point. Choose type intersection point. Select the datum plane, then select curve, Apply or OK.
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Win 7 64 bit (Intel(R) Xeon(R) CPU X5650 @2.67GHz)
24.0 GB
NVIDIA Quadro 4000 + NVIDIA Tesla C2050
RE: Creating Points
If you want to get all of the intersection points at once, you can use Insert>Curve from Bodies>Section, select the curve as the object to section and then your datum plane. This will put a point at every place the curve passes through the plane.
RE: Creating Points
COOL!!!
Thank you Michael and ''mmauldin"
RE: Creating Points
Does anyone know how to obtain the co-ordinates of a "point" with respect to a "datum-coordinate system"?
I'm using NX7.5
RE: Creating Points
Menu Information - Point...
Best regards,
Michaël.
24.0 GB
RE: Creating Points
Quote (mep12tya)
It is as Michaël suggests, but first move your WCS to the datum csys of interest. This can be easily accomplished by right-clicking on the datum csys and choosing "set WCS to datum CSYS". The XC, YC, and ZC values reported by Information -> Point are with respect to the WCS (now the same as the datum csys); the X, Y, Z values are with respect to the absolute CSYS.
www.nxjournaling.com
RE: Creating Points
The simplest solution is to place the WCS on top of the Datum Csys, then check the coordinates / read the XC,YC,ZC values. ( Which relate to the WCS.)
Tomas
RE: Creating Points
There will be a new Analysis function in NX 9.0 which will 'Measure' the location of a Point relative to either the current WCS, Absolute Zero or a specific Datum CSYS. In the case of Absolute Zero or a specific Datum CSYS, you will have the option to create an 'associative' Measure Feature which can also define separate Expressions for the X, Y and Z coordinates. For now, the best that you can do is using the Information tools to extract the values as a non-associative text listing. Of course, NX Open program could be written that could do this as well and perhaps some have already been developed to just that which someone might be able to provide for you.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
