heavy load gear box with loose center distance
I have a gear box which gear specs and drawings are in hand, but the center distance of mating gears are more than standard ([z1M1+z2M2]/2 )and the geometry of gears do not match to gear specs. here is the drawing of 2 mating gears in attachment which center distance is 544.410+-0.125 according to chassis drawing.
RE: heavy load gear box with loose center distance
See my replies in your other post where I explain why.
Ron Volmershausen
Brunkerville Engineering
Newcastle Australia
http://www.aussieweb.com.au/email.aspx?id=1194181
