Saving SolidWorks Drawings into AutoCad format
Saving Drawings into Autocad format is working well, using the mapping functionality to place certain types of things onto layers. The tool allows you to choose dimensions onto it's own layer for example as you export, it recognizes the different features on a drawing well enough and the map file works to help. The only concern we have is that any blocks in SW that have attributes assigned to them don't take the colour property from the mapping file.
Not a big issue, it just would be damn cool and slick if the blocks with attributes were to take the colour from the map file created. (so it would be white on black rather than black on black.
smilin
Snowshoe2
smilin
Snowshoe2
RE: Saving SolidWorks Drawings into AutoCad format
Sorry, but I never understood the concept of saving SW drawings to Autocad. Why not use the SW drawings to keep the parametric capabilities?
Saving to ACAD is now duel effort to track drawings. I have done this at other companies, SW eventually won and ACAD being removed.
Chris
SolidWorks 11
ctopher's home
SolidWorks Legion
however, large multinational companies have policies of project as builts submitted in AutoCad.
We did some manual cleanup and the drawings will be submitted later this week.
Link
It's been 5 years since I used both together.
Chris
SolidWorks 11
ctopher's home
SolidWorks Legion
Scott Baugh, CSWP
FAQ731-376: Eng-Tips.com Forum PoliciesBerry Plastics
Cad Admin\Design Engineer
GEASWUG Greater Evansville Area SWUG Leader
www.scottjbaugh.com
not sure if the below package could help or not Scott, if you look at it let us know what you think.
http://www.javelin-tech.com/main/products/plantwor...
all the best
Snowshoe2
or sometimes called Steve.
Having learned Autocad in college, I remember Zoom all... That's about it. LOL
David
Check out my professional profile and connect with me on LinkedIn. http://lnkd.in/fY7-QK
