Heat Treat Condition for Welding Procedure Qualification per Section VIII
UG-84(h)(2)(b) specifies that the test plate material, (of the qualification), shall be in the same heat treated condition as what is used in production. My understanding is that there is very little difference between the normalized and quench and tempered heat treat condition for P1, Gr. 1 or 2 steels in regards to impact test results. Is this correct?
RE: Heat Treat Condition for Welding Procedure Qualification per Section VIII
1. Normalized
2. Normalized and tempered
3. Quenched and tempered
Incorrect.
