Integrated Nastran and Seperate Nastran solver
I have worked in Nastran NX that is integrated with UG NX software. And also worked with integrated solver-Model Solution which is in I-deas SDRC.
My doubt is, whether if i have a .dat file and need to feed in NAstran solver seperately, then do i need to feed so many codes. Or it is as simple as it is integrated with some pre-processing softwares.
RE: Integrated Nastran and Seperate Nastran solver
Hello!,
I don't understand your question, please re-explain, thanks!.
NX Advanced Simulation includes NX NASTRAN BASIC, then when solving a model is the preprocessor (NX) who writes the NX NASTRANS input file (*.dat), launch the nastran solver for "number crunching", and after execution of solver than reads the results (*.op2 file) in the NX postprocessor ready for graphical verification of results, so simply.
If you need to write your FE model using another solver formats, say Ansys, Abaqus, LS-Dyna, etc,.. then you need to have the proper ENVIRONMENT license to do that. Because Advanced Simulation is a solver-transparent pre- and post-processor for finite element analysis, the options, commands, and techniques available to you vary depending on your selected solver, analysis, and solution type.
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48011 BILBAO (SPAIN)
WEB: http://www.iberisa.com
Blog de FEMAP & NX Nastran: http://iberisa.wordpress.com/
