Oilon water absorbtion
I'm thinking of using Oilon plastic as a bearing material in a subsea application but can't find any consistent information on its' water absorbtion rate. Data sheets I've found on line have values ranging from 0% to 6.2%, does anyone have reliable information as to what the rate actually is?
Thanks for any help.
Pete
Pete
RE: Oilon water absorbtion
You would be better using a lubricated acetal - either with silicon based oil or PTFE.
H
www.tynevalleyplastics.co.uk
It's ok to soar like an eagle, but weasels don't get sucked into jet engines.
Pete
