Need help in macro to create dimension for the surface points
Hi
I need to create the dimension of the section surface like i have shown in the attachment using vb script.
I have extracted the points and its coordinates using a script..... Now i need code/script to add visual dimension like tht with the coordinate details available...
I tried with some sendkeys options..but not working properly..Moreover send keys works only in VBA..
Any suggestions.......................
Barath
RE: Need help in macro to create dimension for the surface points
Hi
Actually I have never used this annotations options bfore..Does Annotations gives the coordinate of that point with respect to local coordinate.
Barath
