changing folder UGII folder permissions
I am using NX8.5
I started using assembly files recently. (I am new to NX) Even though I have set up to loading options as "AS SAVED" I am loosing the link as soon as I close NX and reopen later.
NX support team asked me to change the folder permission of UGII folder.
I am using Win 7 64 bit. I did everything but still UGII folder is only a read only file. Missing something.
Would any one be able to help me.
Raindi
I am using NX8.5
Raindi
RE: changing folder UGII folder permissions
NX 6.0.5.3 (NX 8.5 Testing)
Windows 7 64
Thank you very much for your reply.
I didn't realise that I can save the folder anywhere else. I thought I only need to save their for nx to work properly. If I save the file some where should I need to set any reference or pathway to connect or is nx is smart enough to remember.
Thanks in advance.
Raindi
UGII_LOAD_OPTIONS=<path>\load_options.def
This way NX will not only know where to save any changes that you make, when you 'Save as Default' from the Assembly Load Options dialog, but also where to find them when you select the 'Restore Default' option. There are two other options which will allow you to 'Save' and 'Open' other copies of the Load Options file to any place that you wish, just that NX will NOT automatically know about these copies, only the one that the variable is pointing to.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Ben Loosli
Thank you very much.
I created load options file and saved it in a new folder. (Not under prog. folder)
Everything works fine.
Now the other doubt I have is, should I need to create new load options file and create new environ. for every new assembly that I create?
Thanks in advance.
Raindi.
In the file -> utilties ->customers defaults Gateway geneeral tab directories define a default folder for part file directory. After all don forget to clear the dialogmemory Preferences userinterface tab general, button reset dialog memory.
