slooooooww pneumatic torque driver ???
the problem = current torque drivers revs (RPS) are too fast - causing threads to strip
4 in/lbs torque setting is fine, its just the high speed thats giving our production operators trouble. can someone recommend a slow revolution torque driver ? Name or website ?
thanks for the help!
RE: slooooooww pneumatic torque driver ???
http://tjtools.com.au/torquemultiplier.html
I assume you cannot adjust the current driver / source to achieve the desired outcome.
Lyle
Which brand/model number are you using now?
We've used the ASG TL-6500 before and have NO problem driving fasteners at 4 in-lbs. (We drive some #2-28 plastite screws into plastic bosses at that torque)
When you call them make sure you give MUCH more information than you gave here.. Fastener size/thread type/material joining/thread length,etc...
