Higher Rating for Small Fittings
Hi everybody,
In all of the projects that I was engaged in, small fittings (<2") have higher rating with regard to larger ones. Does anybody know the reason for this?
RE: Higher Rating for Small Fittings
See the post on 31.3 structural strength which covers similar things. Also a #900 flange is the same dimensions as a#600 for 2" and below. There is so little difference in price it is easier to have one size of pipe and flanges to cover all pressures.
That's all there is to it I'm afraid, there's no magic formula or greater technical reason, just years of past experience.
LI
- In small sizes a 3000# fitting doesn't cost a whole lot more than a 150# fitting, but:
- It's less likely to break if stepped on.
- It's less likely to break if something heavy falls on it.
- It's not going to be perforated by corrosion anytime soon.
- It will be useful when the rig crew needs to kluge up a hydraulic system to deal with some emergency, but they have no stock of loose fitings, so they have to cannibalize your product.
Mike Halloran
Pembroke Pines, FL, USA
donf
