Remove excess material in IPW.
Hello All,
When machining and there is a significant piece of material that is left after getting effectively "cut off" by an end mill, the IPW rightfully shows the separated pieces. In the following operation, I have been using trim boundaries to avoid these excess chunks. However I wonder if there is a way to selectively remove these from the IPW before the next operation? Or any bits of advice as I am a noob to level based IPW'ing.
See JPEG attached....
Kevin
RE: Remove excess material in IPW.
I'm not a 'CAM guy', but have you simply tried selecting and then deleting them?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
The picture you see is at the end of a toolpath visualization. At that point, before selecting OK or cancel (which removes the render/visualization), the selection bar filters are grayed out. Nothing to pick, I did try though.
Dovetail question: I chose the option to "Save as component" of the IPW in that same menu, and a component is created as a child of the the main file. In that child the IPW resides as a Facet Body. However, even though they are three separate bodies, they select and act as only one entity and I was unable to delete the excesses. Any idea how to "break" up a single facet body made of multiple bodies?
Kevin
What version of NX are you running?
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
If you're running NX 8.5 I thought I had a solution (I should have checked before I posted my previous question) but it will only work with Solid or Sheet Bodies. Sorry...
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I use to make a fake operation to remove it, if I need the IPW for further machining.
ie. Planar profile with a large diameter mill.
kukelyk
Fake operations is the way to go right now, until "chunks" can be clicked and deleted someday.
Proud Member of the Reality-Based Community..
To the Toolmaker, your nice little cartoon drawing of your glass looks cool, but your solid model sucks. Do you want me to fix it, or are you going to take all week to get it back to me so I can get some work done?
I am running 8.0. I will use a fake op. Thanks to all.
