Spot Welding in Multiple Locations
What is the proper way to show a spot weld that's repeated in several locations within an assembly? I have four identical brackets that use the same spot weld. I've attached an image of how I did it, please tell if it appears correct. Thank you.
RE: Spot Welding in Multiple Locations
I don't know what standard that conforms to (or not), but that's my gut feel.
tg
