How to change the position of the text on the leader?
Hello everyone,
I have a (maybe) simple question. I want to change the position of a note with a leader so the leader is aligned with the bottom of, not the text, but a box around the text.
I have attached an image that shows what I am trying to accomplish and what I've managed to get. I have gotten the leader to be aligned with the bottom of the text but not the box.
If anyone can give me any suggestion or idea how to do this I will be really grateful.
I'm using NX 7.5.
Regards and thanks,
AH
RE: How to change the position of the text on the leader?
I found a way to get this. If you add GD&T symbol of FCF, and change the text aligment to Below Bottom you get something similar to the image. But then you have to RMB and select Style.
On the dialog window, go to Line/Arrow tab and change the parameter "L" to 0.5. Again this is for NX 7.5.
Thanks and hope this helps others!
