ansys analysis loading vs actual testing conditions
Hi all,
Im investigating the response of lattice structure to harmonic excitation. i have a cubic geometry whose base will be fixed to a shaker table with maybe two screws.the unit is small.
my question is in your experience are the actual test load conditions represented better with applied force in ANSYS anlysis or is pressure loading also accurate. i dont have any particular loading conditions yet,my aim is simply to make test results match analysis results to verify the vibration behaviour of the structure.so i need to know what matches shaker loading conditions the best,pressure or point forces
