Thermal Expansion - Elastic and Plastic Deformation
Hi Everyone,
I have a general question here which may or may not be a stupid one but I'll ask it anyway.
If a material, let's say mild steel for example, is heated up it will expand. When it cools it will contract again. Does a stress-strain curve as seen in typical tensile tests apply to thermally induced strain? I suppose another way of putting it is: can you have thermally induced "plastic" and "elastic" deformation in a metal.
I am asking because I have a problem where something will be heated to a given temperature and I would like to know whether or not it will contract to its original dimension, or contract to a dimension different to the original.
If anyone knows any good resources on this topic please it would be helpful if you could share them.
Many thanks,
Tom
Many thanks,
Tom
RE: Thermal Expansion - Elastic and Plastic Deformation
I have one additional comment to help improve your writing style. The first two sentences of your post added nothing to your question. They only projected your insecurity.
The component being heated is not constrained and is free to expand and is free of residual stresses.
Further to my original question, is there a temperature limit for any given material after which it will not return to it's original dimension once cooled again? If so, what is this temperature limit called?
I would like to try to find more information on this in books but I am unsure as to what to search for. The name of this temperature limit would definitely help. If anyone could provide me with any other topic names to search for please that would be very helpful too.
Many thanks,
Tom
But, I'd say if there are residual stresses in the part (for any of several possible causes including cold work or welding) then an excursion past 400 F or so will bring on a certain amount of stress relief due to temporary lowered yield strength and possibility of distortion. The higher the temp and longer the time at the max temp the greater the stress relief.
see page 3 here
http://www.gietech.be/LinkClick.aspx?fileticket=vd...;
Yes I was referring to a change before the melting point is reached and melting of the metal occurs.
It is this change in crystal structure and grain size that I need to look into further for the metal in question. I will also look into relieving of residual stresses as this seems to be a related topic. Thanks Tmoose for the link.
Once again thanks very much for taking the time to give me a hand.
Tom
Without thinking I said ok. Now that is the last Assy that jig can be used for because it all shrunk.
I would guess you get my point about material and temperature.
By the way the material was 17-4 PH
Cheers
I don't know anything but the people that do.
