NX7.5 - SURFACES AREA
I need to calculate the surface area of an assembly, for paint coating purpose.
What is the most accurate way to do this operation?
Analysis→Measure Face seems to be more suitable, but since I haven’t use this tool, I am not sure…….
MZ7DYJ
RE: NX7.5 - SURFACES AREA
Measure bodies will report the entire surface area of the selected body(ies), this might be a little faster if you are interested in the surface area of the entire body and not just certain faces.
www.nxjournaling.com
Thanks for your answer!
MZ7DYJ
Great tip, thanks!
MZ7DYJ
