pdf file opening in Solidworks- Can't reset Default Program
I was trying to open an Illustrator file in solidworks. I do not have Illustrator. After that experiment, all pdf files that I tried to open were reverting to Solidworks as the default program to open, unless I right-click and select Acrobat. This isn't horrible to have to do but not possible in a email as that selection is not present in the right-click menu.
I went into default programs on the start menu and could not select Acrobat for pdf as the default.
Is there a setting in Solidworks that I need to change?
RE: pdf file opening in Solidworks- Can't reset Default Program
-handleman, CSWP (The new, easy test)
- - -Updraft
