How to trail zeroes in drawing
I have dimensions that I need to display with .0 but even setting the dimension to one decimal display it only displays it as an integer
I have tried to change the lead_trail_zeroes & the lead_trail_zeroes_scope to default and all but it has not fixed the problem (this was recomended in a previous thread)
Any idea why even changing these settings that the zeroes still will not display?
RE: How to trail zeroes in drawing
Trailing zeros to show decimal places for a default tolerance are not allowed with ASME Y14.5M for metric dimensioning.
After setting lead_trail_zeros to std_default, did you create a new dimension? I don't tink changing that setting will change existing dimensions.
Ben Loosli
