Flushing of dead legs (flexible flowline).
Can anyone recommend a potential flushing frequency for a dead leg line with potential for stagnant fluid causing internal corrosion (degradation of flexible flowline carcass). The line is a 6” Production Jumper- 316 SS carcass - MAOP 200 barg from well to manifold.
RE: Flushing of dead legs (flexible flowline).
If it's a new line, but you've had experience with corrosion in similar lines, then use your experience to tell you how long to go between inspections. If you know that you find corrosion when you do inspections every 5 years (for example) do inspections at the 3 year mark. If no corrosion, then go up.
Also, flushing a dead line periodically will reduce the chance for corrosion buildup.
Want to know the do's and don'ts of Eng-Tips? Read FAQ731-376: Eng-Tips.com Forum Policies.
English not your native language? Looking for some help in getting your question across to others or understanding their answers? Go to forum1529: Translation Assistance for Engineers.
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
