Glueing test tags - Which glue?
Hi Guys,
A client of ours wishes to have us glue test tags to their valves.
Has anyone any recommendations on the type of glue that would suit best.
They will be outdoors in hot sun.
RE: Glueing test tags - Which glue?
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
Temperature?
Epoxy?
Glue suitable for conditions and used for car motor-rooms?
The tags will be stainless steel and the valves will mostly by painted WCB
Cheers
If the valve bodies are brass, bronze, steel, or aluminum and you can remove the paint, metal-to-metal is OK with a quick-set metal epoxy. Super Glue is one brand, I thinnk Permatex has one, and we have used Loctite Hysol E-120HP. The valve shop guys once ran out of glue and got some from a golf club repair shop that was really good too. They called it shafting epoxy.
All that said, to survive and last -- clean, clean, clean your surfaces. Rough 'em up too.
Finally, glue is good but chains (or straps) are better.
Best to you,
Goober Dave
Beaded chains suck and the temperature swings of valves makes it hard to get anything to stick.
If I had to go with a glue method I would choose the double sided adhesive tape.
StoneCold
