Tank of slurry, sealed air intake to generate flow
I've been driving myself around the bend with this problem and feel its a simple solution that someone can comment on.
I have a flow experiment whereby i need to maintain a constant level in a tank. The problem is that the flow rate controlled by the exit value of this tank varies. I constructed a feeder tank similar to the antigravity water experiment whereby a glass is submerged in a bucket of water, filled then turned upside down and lifted whereby the water doesn't flow out of the glass until air is allowed to flow back in and water flows out. It works great for water as the viscosity is low, but i need to use this setup for slurries of high solids concentrations. Because this material is highly viscous, the air bubble takes a second or so to flow up the tank and allow more slurry to flow out. The lag time creates a variable level in the main tank which is not ideal. It also airates the slurry which is affecting the experiments.
See the diagram attached for the setup.
One solution, is how i can get air into the vacuum pressure area to allow the slurry to maintain its level in the primary tank. I'd like this to be automatic, so not someone controlling an air intake value. Obviously the level of slurry in the feed tank reduces as it maintains the level in the primary.
Any ideas?
MAny thanks in advance.
Any ideas?
RE: Tank of slurry, sealed air intake to generate flow
Or is this really about your vacuum feed device?
StoneCold
You may need to experiement with the size and position of the level sensing line and how far below the surface you need to put your main feed tube to stop it sucking up air when the man liquid level drops.
See attached mark up.
Thanks for the comments. I cant move the outlet to the same level as the pressure in the primary tank as I need a pressure to maintain a higher flow rate.
I like the idea of the line. I will think a little more on the pipe diameter and report back. I need a flow rate up to 2 litres a second.
Many thanks
Cheers
Would be good to know if it works. Now I've thought about it a bit more, it might need a float and stopper arrangement rather than trying to suck up the liquid which would then create a bit of a slug in the sensing / filling line.
I dont understand the float system design. Can you explain it a little more. Perhaps this prevents the slurry rising.
Looks good though. Will fabricate something and try it out.
Cheers
The float should sit on the slurry and have the opening above the slurry level to avoid sucking up slurry. A standard domestic ball cock as in your toilet may work very will with a bit of lag as it opens the valve for reverse flow but should seal very well.
Let me know if it works.
LI
I tried a slight variation to your idea. Basically it does not work fast enough. A little more rustic way is that the air intake pipe is left to atmosphere and someone controls the air intake by their thump trying to maintain a constant level in the tank. Not ideal i know, but i cant regulate the air intake correctly.
Will keep experimenting. Let me know if you have any other ideas.
Cheers
Maybe the air inlet pipe needs to be a bigger size.
