Drawing sheet format in file essentially disappears after saving and reopening file
After saving a drawing file, I closed Creo and opened it back up some time later. When I go to open up the drawing file again, the sheet format pretty much changes itself to most of the parameters I adjusted when I originally started the file and everything else disappeared. This has happened to every drawing file I have made.
When I go to start a new drawing the same format I used prior still works just fine.
Is this like a format directory issue or is this something else?
RE: Drawing sheet format in file essentially disappears after saving and reopening file
pro_format_dir full_path_name
pro_format_dir gets set to the full path of your drawing formats
Ben Loosli
