IC TESTING HANDLER
IC TESTING HANDLER
AETRIUM 5050 MODEL IC,S(SOIC, SSOP,TSOC PACKAGES AND ETC) TESTING HANDLER USED IN SEMICONDUCTOR TESTING INDUSTRIES OFTEN USE STEPPER MOTOR ATTACHED TO A SINGULATOR TO SINGULATE DEVICES ACCORDINGLY TO THE TEST SITE FOR TESTING. THIS SINGULATOR ASEMBLY USUALLY COMPROMISE A 2 ROLLER ONE IS SMALL AND ANOTHER SLIGHTLY BIGGER THEN THE LATER ATTACHED AS A ASSEMBLY. THE MOVMENT OF THE DEVICES USUALLY MONITOR BY A SENSOR
IS THERE ANY WAY WE CAN TAP THE SIGNAL FROM THE STEPPER MOTOR SUPPLY TO MODIFIED THE COMPLETE ASY USING SOLENOID ASSY REPLACE THE SINGULATOR.
