How to analyze the load capacity of structural plywood (5-ply) on 2x2" square joists 24" o
See the link below for the pdf on the properties of structural plywood. Hopefully the highlighted part shows up, indicating the plywood of consideration. Thanks guys.
RE: How to analyze the load capacity of structural plywood (5-ply) on 2x2" square joists 24" o
I'm sorry, but what exactly are you asking?
How exactly would I determine the load capacity of the plywood supported by joists 24" separated. Should I use load-span tables or is there a method to calculate it by hand?
Thanks for the help!
