Boiler feed water pump with PLAN 23
Dear All;
It's regarding the 3 number of Boiler feed water pump installed at site , all having API plan 23.
Following are the observation
As per API plan 23 the seal FO (Flush Out )should have more temperature and high point vent should be in this line
Flush in to seal from cooler should be of low temperature and temperature indicator should be there.
But in our case the flush out to cooler is showing (44.4 deg C (NDE side Mech seal) 38.1 deg in DE seal)
But flush in showing (46.6 & 40 deg respectively NDE and DE)
Questions are
1. Why Flush out as per API notation shows low temperature?
2. Why there is difference in DE & NDE mechanical seal?
3. If pumping ring is reversed during assembly, will lead to this situation?
4. What steps we can do to solve issue?
Thanks & Regards
Questions are
Thanks & Regards
RE: Boiler feed water pump with PLAN 23
Ain't broken don't fix it.
There is no concern because the temperature is under 80 deg C (water loses its lubricity at this temp).
CT
