Part family problem
Part family problem
Part family problem
when I replace a family memebr with the replace command in assembly, an error occur like the image attached.
Solution ?
Thank you...
Using NX 8 and TC9.1
RE: Part family problem
Which image? The two images provided show messages which are the result of two totally different situations.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
There are two errors that I would like to heal.
The first when I replace a family member, showed by the image whit the replace command.
The second when I open the family member and the information say to me that the master part is located in wrong place.
We had all master parts in one location and generated all family member in another location.
Then we had relocated the master parts in a folder structure that represent the standard parts reuse library like done by NX and the family members in new network folder.
Now this is the situation with this errors.
Thank you...
The first message, the one you see when you've changed something in a Part Family member, that has nothign whatsoever to do with where the Part Family master is located. You'd get this message even if you had never moved the files around. This message is simply telling you that you CANNOT make changes too family members, period. They are created 'Read-Only' (at the NX level) and that you MUST make any changes to the Part Family master and then generate new Part Family members.
The second issue, the one that may have been caused by your moving the files around, that one you might be better served by contacting GTAC and have them help you work out those issues.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thank you John, I will open an IR to GTAC.
Thank you...
